You must disable Energy Saver globally.
You must enable Energy Saver on every port affected by the schedule.
You must deactivate Energy Saver efficiency-mode.
Perform this procedure to configure a scheduled time interval during which the switch will operate in low power state. This time interval can be for a week, weekend, or individual days.
You can configure maximum 84 entries in the Energy Saver schedule.
If efficiency mode is enabled, you cannot configure any other entries in theEnergy Saver schedule.
- Select Energy Saver.
- Select the Energy Saver Schedules tab.
- Select Insert.
- Configure the fields as required.
- Select Insert.
- Select Apply.
Energy Saver Schedules Field Descriptions
Use the data in the following table to use the Energy Saver Schedules tab.
Name |
Description |
ScheduleDay |
Specifies the day on which Energy Saver is activated or deactivated. The options are:
ScheduleHour |
Specifies the hour at which Energy Saver is activated or deactivated. The range is 0 to 23. Note:
0 is equivalent to 12 a.m., and 12 is equivalent to 12 p.m. |
ScheduleMinute |
Specifies the minute at which Energy Saver is activated or deactivated. The range is 0 to 59. |
ScheduleAction |
Specifies if Energy Saver is activated or deactivated. The options are:
